I tried using it in my dads truck. I got the rpms working perfect, and the shiftlight is fine. But when I press ok to messure the Hp & torque, it doesn't do jack, but one red light just blinks. What do I do to get it to work? Thanx Antny
When the red light blinks you need to drive the car and accelerate like you were going down the drag strip. It doesn't measure hp and torque while sitting still. Also you need to have the correct weight of the vehicle as it sits when you do the test or the results will not be accurate. The instructions explain a whole bunch of different stuff you can do with it.
