1 - 8 of 8 Posts
I'm doing the 73mm brake upgrade for the front, I'm keeping the stock drums in back for now. Currently I have a 4cyl brake booster and am curious as to what junkyard cars I could possibly use for this swap. The rest of the 4cly brakes on my car have been swapped to the stock 87-93 v-8 setup already.
This is what my list consists of right now for the upgrade I'm attempting, am I missing anything?
94 GT mustang master cylinder
90 crown vic police calipers
stainless steel lines
performance carbon metalic pads
booster??? but not sure which to get. Any help greatly appreciated.
Banned
search Matt90GT and look at his website, as FULL instructions, on everything you can use and how to.
Matt90GT has some really good stuff on his site. I did the same thing you are doing only I left the 4 cyl master and booster. Just turned the adjusting rod out about 1-1/2 turns. This was a temporary deal though as I have switched out to SN-95 brakes.
http://svo73mm.cjb.net/
Darren
You might be okay with the 94 Master cyl, I think it is over 1" 73mm up front with drums gives a real soft pedal if I recal, prob have to gut the Prop valve and use an adj prop valve or use a Crown Vic prop valve to deal with the amount of fluid movement required to fill the larger front calipers.
Definitely look Matt up...his website is... http://svo73mm.cjb.net/
for the front 99up PBR brakes on a 88 which SS brake lines do I get? the ones for the 87-93 or the 94 up?
87-93
I was told by another fellow corral user that I should use the 94 up ones? Now i'm confused as to which to get.
um.. ok..
then do whatever you want...
1 - 8 of 8 Posts
