seems a little generous.On my tuneup using a .056 nitrous jet I use .85 pounds per run with a et of 9.90-10.0.Using the rule of thumb of 100hp per pound of nitrous that equals 85-90hp.The calculator shows 141 at the flywheel,That should be close to 1.5lbs for 10 seconds.My second stage is a .065 jet and uses 1.3 pounds per pass and and comes out to 130-140 hp or so.and the et and mph correspond with the hp gained.
well i was wanting to run a .68Nitrous jet and a .038 fuel jjet.. was told it would be a 150 shot? its saying its a 177? when you say its genorus.. are you saying it will make less power then what it says??
well i was wanting to run a .68Nitrous jet and a .038 fuel jjet.. was told it would be a 150 shot? its saying its a 177? when you say its genorus.. are you saying it will make less power then what it says??[/QUOTE
more than likely,yes it will be lower than the chart says in my experience.
Related Threads
Ford Mustang Forums
9.8M posts
200.8K members
Since 2001
