Which headers to use?
  • JBA 1-5/8\" shorties
    Votes: 3 17.6%
  • BBK 1-5/8\" longtubes
    Votes: 14 82.4%
1 - 8 of 8 Posts
What is your guys take on the 2 headers? Should I got with the JBA's or the BBK's??? I'm basically gonna be running a built short block and ported heads with about 15psi of boost. I was a good improvement, but also no hassles if I had to take the tranny/clutch out.
What kind of gains could I expect from the two? Does one drop off in power over the other? Does one make more torque than the other?
Thanks,
NC_35thPony said:
Get the SHM/Hooker long tubes, you can get the tranny out with out taking the headers off.
Well I never found out is that is true or not, BUT if it is then I would say go with the Hooker LT's!! :)
I know that the BBK's have to be loosened to do ANY tranny swapping or clutch changes, however, produce good power gains! I couldn't get the Hooker LT's or I would have - I went with the JBA's and they REALLY help the top end pull!! :D
Thanks,
The long tubes will give you more power BUT they have two drawbacks. Your car may not pass smog, and it will be more of a pain to install. I like the long tubes but when I put headers on the Panoz it'll be JBA shorties because I want to stay CARB certified and pass my smog tests. It's just not worth redoing the install every two years to pass the smog test.
Re: Re: JBA Shorties or BBK longtubes??????????
You have to do the same amount of work to install shorties as you do LT's
I think when the Hooker's come out for the cobra's my BBK's are going bye bye
Sorry about the off topic Steeda46,
I'm starting to collect info for a s/c install hopefully early in 2003.
I'm not too knowledgeable when it comes to s/c's.
I saw in your sig Vortech mini-race bypass valve.
What is this, what is it's purpose, and does it come in the kit?
sorry again about the off topic
just wondering if you could help out a rookie.
Dave
1 - 8 of 8 Posts
