Had the car on the road today. It Idles rough and mean sounding. It pulls Like an evil spirit running from god....and moving about 35mph and dump the gas and it breaks the tires loose and the car is sideways,(a little scary if your not ready for it) I'd say it runs dam good! Need to set the base timing and fuel pressure yet and do a few other small things.(repaint the conv trim, hood, cowl, replace the stock headers(on order), and bore the EGR spacer out to match the gt40 intake.
congrats, now the fun begins....
Please use Exorcism forum, for satanic related posts :p
Fast90LXStang should be able to help you out with that one :idunno:
congrats on ur car......
I know your excitement, mine is running after 3 1/2 years. Just waiting for the throttle cable to be replaced to take her out (and some snow to melt).
Congrats. :)
Is that 2nd or the top of 1st? You don't have gears listed... with stock 2.73s you can punk fools on the freeway... slow them down to about 50 and drop it into 2nd and you should see at least 70 b4 you see 6k. ;).... Oh... I do miss tacking my speedo in second. ;) (stock 85mph speedo)
Discussion Starter · #7 ·
its auto
its an aod w/trango shift kit. cruising at 35 and dump the gas /..........it shifts to passing gear and the tires come loose. oh ya and 3:73 gears
