WANTED TO KNOW IF THIS IS A GOOD SET UP FOR 300+ ALL MOTOR OR W/ NITROUS ANY SUGGESTIONS TO MAKE 300+ ALL MOTOR PLEASE POST HERES THE SET UP.
STOCK BOTTOM END 302,stock 351W HEADS,X303 CAM OR TRICKFLOW STAGE 2 CAM,VIC JR INTAKE,670 HOLLEY CARB,1 3/4 LONGTUBE HEADERS,PULLEY,NO SMOG,150 SHOT OF NITROUS:joy:
U will not make 300 rear wheel hp with that setup. Better heads are required. with the nos it should be a no brainer.
Yep, the 351 heads arent crap compared to AFR's or other HP aluminum heads... and you will need a little more compression via smaller cc heads or new pistons to get the numbers your looking for. I would say AFR 185's, Victor Jr. Demon 650 and a TFS stage 2 would make 300... and be nasty on the spray..
