Anyone know if there's a rev limiter in the stock computer? I have a 347 Procharged, AFR heads, 36# injectors, msd 6a ignition. It;s going to the Dyno on July 30th. A friend of mine said its the stock rev limiter in the computer shutting it down at 5700 RPM's.
Anyone have a similar problem??
Thanks, Rick
The computer cuts fuel at 6250. I think it starts to cut fuel a little before that. If you are getting a chip burned, they can put the rev limiter anywhere you want it.
