I'm not sure why every non prom thread, gets turned into a prom is superior thread?
You seem to think the prom is "high end". Sorry to disappoint you, but not even close. If you really want to get serious, look at the "real systems". I bet most here couldn't afford it.
It's funny how my speed density system can't compute load. If it couldn't, the a/f wouldn't be consistent. Guess what, it is consistent. It uses all the sensor inputs to calculate load. And it's repeatable.
KB302, I'm curious if you had any issues installing your prom?
Sorry ip, that this thread got derailed like all the others with the typical non sense.
as a complete noob, I had issues. because i was doing a 351w swap, fuel system, and efi swap in the course of a week. it wasn't until a few years later after the term x first hit the market when i installed one another friends car. this was after I was more than comfortable with the pro m. after spending A LOT of time with the system he pulled the plug and took out the Holley and I sold it.
point isnt that one is superior to another, that comes down to needs and wants and mechanical ability. I bought the pro m because it said plug and play and didn't want a tuner raping me $1000. aka didn't have easy access to a tuner/dyno nor the time to have it done. For the most part, and LOTS of engine combos put together without the need to consult,rent a tuner or dyno realizing if i didnt rush and read directions the system has been very good to me.
So when I go on the forums and research Holley with all their followers, there is a lot of help put there NOW. Because there are people like I was who think they know more or better than the system.
The Holley system needs proper directions on fuel system design, starting, charging, grounding etc. these were the problems I had most when first installing the pro m. When I had mastered the basics, going from engine to engine was easy.
