well i went to the track again. i just replaced my stock servo(b) with a pa super servo. well my tranny will still not shift into second gear at wot(same thing it did befor) it will shift perfect if you shift at any other point. i have a pa reverse manual vb. actually it now shifts worse at wot then it did befor. i also torqued the band to 14 ft/pd and then backed off 1 turn.
is it possibly the valve body is bad? also the shifter is set up perfect so there is not a problem there.
if you have had this happen to you tell me what caused it
or i can send the valve body to pa and they will freshen it up for 65.00.
well i guess its not the valve body.i just got my new pa rev/man and still does the same thing. guess i will just get it rebuilt. this really sucks
