I just hooked up my f/p gauge; when I get on it it takes a few seconds for the pressure to rise above 42 psi, then when it does, it bangs & peaks over 100. I'm running a Vortech S-Trim 8 psi, 190 lph in-tank & the T-rex. I am also running a FMU; is that my problem?
TIA,
Lems:confused:
the FMU is doing it if you have the stock injectors. its normal but FAR from ideal
take care,
adam
Lemonade said:
I'm running 24# injectors. I need to change the diaphram in the FMU?
Lems
I don't know. One thing you could do is get larger injectors and a new mass air meter, and ditch the FMU. In my opinion, it just one more thing that can go wrong.
you ned to have an 8:1 disc in the FMU
take care,
adam
