1 - 20 of 27 Posts
is it possible and if so what does it take (no power adder)
With a ported intake it will.:D Stock heads and cams and N/A!
Later, Jason
Nope, shoulda bought an LS1:D
Yes, it is possible. :evil: There are a few on this board. :D Basically it requires a ported intake, all the bolt-on's and a very good tune.
it's seems that forced induction is where the quad cammer (stock shortblock) really comes to live over the 302s
There is also the option of getting a stroker kit. Stroking it out to a 5.0L does well is appears.
Very posible on a 01, but not a pre 99.
I should be sitting right now at around 320rwhp and 325 tq. New dyno #s coming soon.
So only 5 more could posibly come from Maf/TB combi I would think, or better tuning. My car is running SO rich I shoot flames out of my pipes everytime I get on the throttle!
I would beg to differ with that statement. :rolleyes: It does seem to be easier to reach those numbers on the newer Cobra's but, it IS possible for a 96-98 to reach those Rear Wheel #'s on the stock long block.
I was talking from BOLT-ONs Only ...... not undoing even one bolt from the engine!
Sure, if I had done intake work and heads and stuff to my 96 it could have seen those numbers, but I didn't think the person posting the thread was including that, so I didn't!
OK, maybe I was confused but, I thought that what was being said was for a stock LONG block to make those #'s. If that is the case, my car has NEVER had the valve covers off! The only thing other than bolt-on's, is the ported intake. Now, if you mean a bolt-on 96-98car that is still running the stock intake, then I would say NO. I haven't heard of any 96-98's make that kind of power without intake work. :)
OK - we're on the same wave length ... I agree.
I think 325 with a good tune, intake, Longtubes, O/R h or X, pulleys, powerpipe, CAI, etc is VERY attainable. However, I think this will probably be the most power N/A without touching the heads/cams(96-98 cobras). 335rwhp will probalby be the max rwhp seen on the newer 99/01 cobras.
My goal is 320rwhp with an intake and other parts mentioned above. FWIW, I think the originator of the post meant every part on the car without touching the valve covers/heads/cams. I don't feel comfortable messing with the 4 cams, heads, timing chains, etc. However swapping an intake is like a walk in the park for me.
Good luck with your HP goal.
Discussion Starter #15
have any of you guys swapped cams or played around with the cam timing (retard/advance)
Well we'll have to wait and see...
I'm in the middle of all the usual boltons right now and I intend to do a dyno tune after I'm done. Mine is a '96. I agree 325RWHP would be very sporty before the '99 heads. However, I do believe I can hit 300+ with no problem. Anyone got an issue with that?!?!
Down the road, after the wife gets a new car I'm gonna pull the motor and go up to at least 10.5 with forged internals. Then rework the heads, intake, cams, fuel system, and ignition. And yes I know that when I'm done I will have more money than a Vortech kit and still be lower on horsepower. Sorry, just not into forced induction on a car I want to be what I would call "daily driver" capable (which means different things to different people...). Not that there's anything wrong with it, lots of people do it, just not my cup of tea. On the other hand I will have I believe a car that's may be close to 400RWHP that should have fairly mild road manners. I dont think I will hit 400 with this route, but I bet I got a shot at 380 or so. Any opinions?
to be honest, a car with a centrifical is going to have more daily driver street manners than a high compression n/a car.
when you not w.o.t., the centrifical car is going to act like a stock car, you won't see any boost and be in vacuum
Corral Charter Member
I think it's possible. Here's my latest dyno from Abacus racing in Va Beach. I'm showing both STD (Standard correction) and SAE (SAE correction).
Here is the STD run - 320 RWHP:
http://members.cox.net/rdcosby1/images/t45dyno.jpg
And here is the SAE run - 312 RWHP:
http://members.cox.net/rdcosby1/images/t45sae.jpg
Power mods are in the sig. I'd like to think that with a set of long tube headers (and a re-tune for them), and perhaps a larger MA meter and TB, I could get rather close to that 325 RWHP.
Why do our cars always seem to have a dyno graph that looks real wavey? Just wondering, my car has that too, and most graphs I've seen look that way.
I completely agree. A blower will provide a great deal of flexibility [edit] and probably give the broader range of "street manners" vs horsepower. I guess my comments were a little misleading. I dont intend to get really carried away with the compression. Probably somewhere between 10.5:1 and 11.5:1. We're 9.85:1 anyway from the factory. Again, I still need to do some more research but I don't intend to go up to 13:1 or anything near that. And if it turns out that the general conseus is that I wont be able to get in the power range I indicated without major internal changes I will more than likely blow it off. I have been thinking about maybe building a trailer toy, I just dont really want to drastically modify my Cobra that much. Maybe pickup a ragged out V6 and give it a new chance at life...
[edit] BTW Beefcake, saw the ESPN interview, nice job taking your class, congrats! :joy:
1 - 20 of 27 Posts
