1 - 1 of 1 Posts
Is it ok to run an open breather on the valve cover? I have one on cover. When I remove it and put my hand over the opening you feel it being sucked in. If I remove the pcv valve this stops. I am experiencing a lean condition. Could the air being sucked in through the pcv valve into the intake cause a problem? Should i put the stock valve cover cap on?
1 - 1 of 1 Posts
