I need a new gas tank.
is a 2.3 EFI 88-93 gas tank the same as a 86-93 5.0 EFI?
is the fuel level sender the same?
I can mount my fuel pump and pickup in the 4 banger tank if neccessary.
[email protected]
Yes. Stock fuel pumps are the same, too....unless you have an upgraded one already, there's no need to swap.
Ash
86 tank is different than 87-93, but otherwise you are golden. Tuthfully, I don't know if the 86 TANK is different, but I do know they have a specific sender to work with the 85-86 guages.
Bzzt...stock four bangers have 65lph fuel pumps. I believe the V8 cars can be 88lph or 95lph pumps. I changed my stock fuel pump in my 93 this weekend and it was a 95lph pump. Everything else about the setup is the same.
The pumps are exactly the same pumps they are just rated at different pressures. Same for the 88 and 95lphs. Same pump different pressure rating.
