1 - 14 of 14 Posts
Installing my viton seals from Alex's... My question is do I put a touch of lube on them or just push em on??
Assembly lube or oil is what I have always used
  • Like
Reactions: Bentley
I am having to put a correct sized socket and lightly tapping them down the last 1/8 inch or so... Is that normal? Should they bottom out?
Yes that is typical. They do make a specific tool to help install valve seals. I recommend the tool over the socket method
The danger with sockets is they might cause damage to the top of the seal depending on the size/shape of the socket. Something to pay attention to and watch out for.
Discussion Starter · #6 ·
Thankyou, I am being as careful as possible, but you know how that goes.. Thanks for the help
Discussion Starter · #8 ·
Another question... Measuring my spring height.. I have .015 and .030 shims.. One spring is .010 over.. leave it?
I forget what the allowed variance was. I want to say +/- 0.020" but i'd have to do some digging.
I'd probably install the 0.015 shim meaning it will measure 0.005" under your set height. Then i would tap the valve with a rubber hammer to jounce it a bit and remeasure it. You may find it you've gained a tiny bit of length. I remember doing this to all my springs before measuring.
I would defer to someone with a little more experience however as it's been almost 2 years since I installed my last set of springs.
  • Like
Reactions: Bentley
Discussion Starter · #10 ·
So you did this then removed the spring and measured again? The fancy little micrometer Alex's sold me measures the height where the spring goes without the spring installed...... I had thought about installing the 015 shim too....
I think I did. To be honest i can't really remember now. I do recall performing the above procedure but am now second-guessing myself. I'll let others chime in here.
But given 0.010" longer, or 0.005" shorter, i'd take the 0.005"
  • Like
Reactions: Bentley
It came to me in my sleep.
I used checker springs. The ones sold specifically for this purpose were a tad light so i bought springs from Mcmaster or Grainger or one of the big industrial distributors. I assembled my shims, spring and retainers and measured. I would tap the valve a few times to make sure the retainer was fully seated and measure. Once i was good with the number I swapped the spring out for the real spring
  • Like
Reactions: Bentley
Discussion Starter · #14 ·
I pulled the 3 seals I had installed and threw them away with some new ones ordered..
Thanks for the lead on the valve seal installer, it works so nice..
1 - 14 of 14 Posts
