I am putting in 03 pumps and tank this week. Will my stock wiring harness fit the cobra pump assembly? If not what did you find was the easiest and best way to make it work?
Going on a 99 GT..............
Heya,
Here's the writeup I did of the install of the 03 cobra tank/pumps on my 99GT a year ago: http://www.corral.net/forums/showthread.php?s=&threadid=161292
Should be all you need. I believe the wiring harness on 01+ GT's matches up and doesn't need to have the connector from the stock GT pump spliced into the 03 cobra setup like on our 99's.
Later,
SOHC
99 GT..... new motor bein installed...still waitin on KB to send me a polished blower after waiting for 5 months.
I did this about 4 weeks ago on my 2000GT. You'll need to cut off the plug that's on the stock pump, and write it in place of the one on the 03 Cobra Pump. The wires lines up, but the plugs shape are a bit different. That's all ya gotta do......otherwise it goes right in with some grunting and pulling.
Oh, and good luck with the blue evap. canisters, they're a MAJOR PITA.
-Eric
