i just installed my novi and everything went fine but when i started it the pressure is between 60-70 i have 30 injectors with a 6-1 fmu i havent hooked up the boost gauge to see wat the vacume is i tried adj. the regulator but it didnt move the timing is at about 8* anyone now wat would cause this i was told its either the fmu,regulator,vacume leak is there anything else it could be or how do i check the fmu,vacume ,regulator thanks i also have a bbk inline pump but i didnt put it in yet with a 255 intank pump that is in
