Has anyone installed the nice Ford Motorsport crankshaft damper on their 94-95 car? If so can you give me any advice before I get started in particular about the part of the instructions that says to place the damper in boiling water for 15 minutes. Can't you just use a installer? If anyone can help let me know. Thanks
PMS Tuning Forum Moderator
Yea you have to put the balancer is boiling water so that the center will expand. Once it cools down it will shrink back down...this makes installation much easier. You might have to grind a little on the bottom bolt of the water pump for clearance. Install is pretty straight forward. I also went to Lowe's and bought some longer Grade 8 bolts.
Troy
