Hey guys, I’m looking for a bit of input from people with similar experiences on a fueling issue I’m having. Once again this car is testing my patience to the max. Here’s a few relevant details on my build:
FordStrokers Dart 363
Custom cam from Woody
11R 190 heads
Billet 7875 Turbo Setup
Glenn’s Performance 1000hp Fox Fuel Kit
- I went with an Holley 525lph pump assembly (complete drop in assembly with billet hanger) instead of the Glenn’s Walbro 450 pump. Lines are -8 supply and -6 return from Glenn’s along with a -12 in/out fuel filter and Glenn’s FPR.
Deka 80lb injectors (authentic, not knockoff stuff)
BBRC Rails
Terminator X for tuning
Fel-Pro MLS head gaskets
92 octane fuel
I have an upgraded alternator and voltage stays steady near 13.6-14.2 volts at rpm.
No leaks have been found or evidence of fuel leaking under pressure.
Feel free to let me know if I left anything else that’s pertinent out.
We were on the dyno tuning the car, data logging each pull, and progressively raising boost via the Hallman manual boost controller. All was well and the car was making solid power. We were nearing our target boost level and at roughly 5500 rpm the head gasket blew with the expected coolant everywhere and billowing white smoke from the exhaust. Based on pulling the plugs it looks like cylinder 5 let go, which is fueled by the first rail on the supply feed from the pump (I feed the driver side rail, from driver to passenger rail, then from back of pass rail to FPR). At the time of the failure the car was making 640whp (5500rpm) and 670wtq (4300rpm) on a Mustang dyno with past runs showing peak hp at 6300rpm so we weren’t even at max power output when it let go. Timing was at 12 degrees and AFR was 11.2-11.5 up to the point where the pressure fell off a cliff. The tuner let off as quickly as possible but the head gasket went almost instantly. We went back and looked at the logs and at the time of failure we were at roughly 16lbs (1-2psi over our target but shouldn’t have been enough to blow the gasket) of boost and injectors were flowing a bit over 500lbh. Fuel pressure was at 60psi and then dropped like a rock to about 40psi (I will confirm exact on data log) and pop went the head gasket. When the fuel pressure started the drop the Holley did try to compensate and the injector rate rose to 80% but it wasn’t enough. Luckily it doesn’t seem like the block was hurt and there is no coolant in the oil.
Everything in the fuel system is brand new and has roughly 200mi on it. The fuel pump is powered by dedicated 10ga power and ground wires and is fused through a 40A circuit breaker. The breaker did not trip. As there are only so many components in the fuel system, I’m leaning towards this being a pump failure to perform in some manner. Maybe it got hot from repeated pulls and couldn’t keep up? Aeromotive specifically tells you to place the return line in the baffle box of the tank where the pickup is, could that have caused aeration and led to a failure? Seems like the car would be using more fuel under boost and returning less? The FPR seemed to be doing its thing as it was seeing 60psi and rising as expected.
Has any one had a similar issue? Are these Holley pumps junk or maybe I just have terrible luck? I had a Aeromotive 340 pump fail on me before (it was just completely dead as where my current pump still primes up to static pressure). I’m frustrated with the car and now I’m going to be replacing head gaskets and I sure as hell don’t want to retain the fuel system as is if it’s insufficient, but I’d also like to not just throw parts at it. Any input would be great from people who have experienced similar issues or if there’s something I’m missing with the fuel system.
Here is a link to the exact pump I’m using:
www.holley.com
11R 190 heads
BBRC Rails
92 octane fuel
Holley Sniper 12-347 Holley 525 LPH Fuel Pump Module
This direct fit fuel pump module will drop directly into any 1983-1997 Ford Mustang EFI fuel tank. The module has been designed with a 525 LPH (liters per hour) Holley fuel pump that will support up to 1200 EFI or 1450 Carbureted horsepower (HP Rating @ 60 PSI at 13.5 Volts / 17 AMP Draw) The...
