Couple of questions:
1) Has anyone here ever replaced the "inner" tie rods? If so, how is it done? I pulled the boot off (which I have no idea where to get another one other then ford). Any suggestions?
2) Where can I get the front bushings and bolts that go through the rack/pinion?
Thanks,
Tim
hey...
..give me a call at home...or on my cell.. you do need a "special" tool to remove the inners...I can get you the bushings, bolts and sleeves. on mine I bought the "poly" ones from Engery suspensions and they worked fine.
Randy Stinchcomb
Re: hey...
Randy Stinchcomb
randy,
you have a PM.... with my number, can you give me a call tonight if possible please?
I replaced the inner on mine. Yes you do need a special tool, but I do front end work at a Ford dealer so it was no big deal! Make sure you get it aligned afterwards!
