i am currently building a 351 twin turbo the guy doing the turbo kit for it says it should make between 750-800 to the flywheel what size injectors should i use???
depends, how much of that power is N/A and how much would be boost?
I'd also need to know a little bit more about your combo....
he said it was only going to be 10 lbs of boost. 351 victor jr heads with XSR cylinder heads port job, victor jr spyder intake and twin turbos not sure on size of turbos but that will give you a little more information
