Ok guys, Im not sure this is the right section but i'll give it a whirl anyways.
I have done a fair amount of research and am getting mixed signals and a little confused to be honest. I'll try to give as much info as possible so hopefully you guys don't have to do much searching.
I'm looking at getting a set of 24lb injectors for my 1990 5.0
I understand that i'm looking for the blue injectors, but Im not sure which to go with.
Im looking at the "blue TOP" injectors bosch # 280150947
the entirely blue injectors bosch # 280155715
Both are supposed to be 24lb and i believe the jetronics (ev1) style connector.
The blue top are the fatter injector and the blue body are the slimmer.
Will both fit stock harness and fuel rail?
If so, i will just go with whichever I can find cheaper.
They should....I bought accelerator 30s, they are skinny. It's not what it looks like in the middle it's the top and bottom.
Thanks for a quick response!
So both are the same height and plug style? I just don't want to buy a set then have to get plug adaptors.
