I've got a 98 GT I want to put a kill switch on, but i dont want to kill the power to the radio or clock, because i really don't want to set the clock or mess with the radio every time i get in the car. So i was wondering if there is a way i could wire one in that just killed the fire to either the coil packes or the starter. Any info will be greatly appricated.
Fuel pump kill switch is a great idea. I had one on my 90 GT and it worked perfect, and was too easy to wire in.
Find out what fuse controls the fuel pump. Then go to the back of the fuse block and find the corresponding wires. you cut one of them splice in a toggle switch and your good to go. when the switch is on, current can flow through. When its off it will not, thus disabling the fuel pump. Youcan add wire to the line if you wanted to locate yor switch elsewhere. Its easy
