has anyone done individual coils with the pimpxs from the expantion port. I will ask on there tech site when it comes back up. just thought i would ask here.
I'm planning on turboing my car, now I want to flip my upper. That's sweet manI installed LS style coil on plug on a 327 sbf stroker single turbo in a 92 fox. Wired it with an MS3 Evo, stock LS coils, tfs box R, 120#injectors, stock ford cam sync, DIY autotune crank trigger, wilson throttle body with iac and tps. Setup works great. The MS3 evo was a bit of a pain with the flying lead harness.
if you use the DIY autotune crank trigger you have to put a pull-up-resistor between the signal and 12v ref otherwise it wont work. The cam sync does not require one.
