1 - 20 of 39 Posts
I'm about to do a junkyard aluminum Explorer shaft in my car,and just wanted to see what everybody's improvements were after swapping over from the steel one. List your ET,60',and HP gains (if dyno tested).
i never had any track times to back up the results, but it was a noticeable improvement for me. car felt like it revved quicker and go tinto the power band quicker. it also had a weird hum to it once you hit a certain rpm, i kind of liked it after a while
If I had to guess it would be .05
Yes..........the "factory" steel shaft is quicker by 0.05 than an FMS aluminum shaft.............
I broke my FMS aluminum and put my spare factory in it and it went faster!!
Aluminum tends to twist/absorb torque as I suffered big time in the 60 ft area.
Needless to say I now run a Mark Williams 3.5" Chromoly shaft...........
There are better things to spend money on..........
Discussion Starter · #5 ·
I appreciate it,but I don't see mine twisting a d/s in the near future. As far as money spent,my total cost is only going to be $70.;)
Discussion Starter · #7 · (Edited)
Well, for 70.00 I would buy 2, one for a spare:D
Well,I grabbed one from the u-pull-it yesterday,and dropped it off to be shortened today. Just some info for the masses here,the Explorer shaft is a 3 1/2", like the FRPP unit ,and I just have to swap the slip yoke. No special U-joints required either,it uses the same as the factory Mustang joints.:cool:
Discussion Starter · #9 ·
what year did you get it out of?
It was a '96 or '97 with the V6. All the Explorers that I've seen from the first model year up have aluminum shafts,except for the 2 door sport versions.
Any thing that is rotating the lighter it is the better.
This is where things can get expensive. Watch the ounces and the pounds will come.
Tim
Discussion Starter · #12 ·
I have one out of an Aerostar van right now.
want to have an extra ready just in case.
I was looking at the Aerostars as well,and they look like a broom stick next to the Explorer shaft. I've heard of plenty of people running them with no problems though.
Discussion Starter · #14 ·
on my 95 I used to have it felt like the car revved quicker, don't think it was actually any faster, just part of the whole package
Discussion Starter · #16 ·
Well,I grabbed one from the u-pull-it yesterday,and dropped it off to be shortened today. Just some info for the masses here,the FRPP shaft is a 3",where the Explorer one is 3 1/2",and I just have to swap the slip yoke. No special U-joints required either,it uses the same as the factory Mustang joints.:cool:
I need to correct myself here,the FRPP shaft is also 3 1/2".
Discussion Starter · #17 ·
Finished product
Got it back today,just need to put the slip yoke on it. Here it is alongside a factory piece.....
That is not how I would shorten one. Hope it works for you.
Tim
Discussion Starter · #19 ·
1 - 20 of 39 Posts
