1 - 20 of 27 Posts
Agent47 makes a kit, i go to order and the site says unable to find, I emailed Mike from Agent47 and im waiting for a response. Anyone know of any companies that make some? Ive seen the home made ones with U brackets but im looking for a proper kit, before i home depot special it.
Reason for these links? Im going to corner balance the car before i go back to Lime Rock Park and these would help tremendously.
Best
Purvis
Discussion Starter #2
Do Fox guys convert to the SN95 front bar setup and mounts, then just buy the MM adjustable bar?
If you decide to fab your own the Matthis book has drawings and a parts list.
You might get some preload in the front bar with the stock set up, but honestly, I don't believe it's worth the hassle in trying to set it up properly for the minimal gains you will receive...my $0.02.
Agent 47 isn't operating anymore from what I have heard. Interested in what you come up with. I have the Matthis books if you need scans....
Thats strange i just installed their brake cooling ducts back in June. And spoke with Mike Winston on the phone, he said they were relocating warehouses, never mentioned being out of business.
I want to corner balance the car, and the guy who is going to help me do it said you want adjustable endlinks to zero out the front bar so each side has the same tension.
Interesting - the problems noted in the other thread. I have the Power Grid pieces and have had zero issues with them. I am going to cycle the suspension and watch how they react during travel.
probably misinformation on my part. but seriously, i have the scans if you want em ;)
Discussion Starter #15
Are they adjustable and im guessing these are not for mustangs, so which ones did you order and which ones should i order for a 89 mustang?
84-87 front, 88 front, 88 rear ? I need to measure my endlinks now and figure out if i need short or long.
Do you realize those UPR links are for their "drag race" rear sway bar?
Those links are probably too long to use on a factory Fox style front bar... I guess you could cut the center portion of the link shorter...
Discussion Starter #18
Yea, Im most likely going to have to customize these things.
Just say no to Unauthorized Product Reproductions. Those Zero Lash pieces look interesting. Curious to hears Jack's comments on those.
Discussion Starter #20
The zero lash looks good, but i dont think they are adjustable. Im dying to get the car dyno tuned and corner balanced before lime rock park in oct.
1 - 20 of 27 Posts
