took th car for a ride and when i got back home the idle is now going from 800 rpms and going up yo 1500-2000 rpms and just hanging there.it will come down after a few seconds.its driving me crazy.it just started doing it sat.any one have this problem ? putting on the air will aslo make the idle go crazy and just hang up for a while.
Discussion Starter #2
went out to my car on lunch and played around with it.i pull the hose off the I.A.C and to my suprise the car stayed running.before when i did this the car would just die.is the IAC the culprit.any more tips ?
I just did a bullitt swap and my car is doing to same thing. I think is my TPS. I had to extend the wires and i may have a bad connection. It started to go away after while put when i reset the comp. it came back.......Greg
Corral Charter Member
Seems like either the IAC is bad or the throttle blade needs to be backed off a little. Since it just started happening, I bet its the IAC.
Steve
