Getting codes KOEO 22, 41, 53, 54, 67. Was putting in gauges and cut wires in main harness. Heard voltage popping when touched. Fixed cut and abrased wires but computer codes above are present. Thought TPS was bad but get no voltage between green and black wire. Have voltage on orange (5.2v) and have voltage on green to ground (5.3v). Have checked continuity on all broken wires and fine now. Have I fried computer or what? I did get another TPS and same result so think I have a common problem.
Discussion Starter #2
Oh I almost forgot I also have code 35 and 51. This all the sensors on the one side of the computer . This is why I think I fried it. Also I have cleared the codes several times and the same ones come back. Is there any component that is common to all these sensors that could have been burnt instead of the computer.
And Oh yes I have ordered my sign (STUPID)
If your tps is reading 5 volts you can jumper wire pin 60 to pin 51 and it should bring the voltage back down to 1.0 where it should be. ( old mass air conversion trick!! )
