Update: With the nice weather here, went out to the garage to change the oil and take the car for a drive and guess what I found in the oil? COOLANT! I'm so bummed right now. I guess I didn't replace the lower intake gasket correctly and I'm doing it again. I drove the car last summer ~400 miles after doing the lower and never noticed any coolant missing. I even drained a little oil after ~150 miles to see if any coolant would appear (let the car sit for a couple of days) and all that came out was clean oil. When I popped the hood today, the rad was completely full but I noticed the overflow down ~1/2" (I had marked a line to gauge). Just performed a pressure test and it dropped 1 PSI after 22 minutes. When I finished the lower a year ago, I pressure tested it and it had dropped 0.5 PSI after 1hr 40 min and I thought it was my Mitivac cap leaking (had to use a distributor o-ring to get the cap to seal). Guess the problem was there from the beginning.
Before I tear it down again and do it all over again, I'm wondering a few things:
1 - Did the silicon end seal "fingers" maybe get under the gasket and caused it to not seal properly? Maybe I should "snip" those fingers off?
2 - Did I let the Ultra Black dry too long before torquing the lower? (waited almost 1 hour)
3 - I used 4 studs to align the lower but it slipped out of my hands and dropped ~1" before bottoming out. It was on the studs so it landed straight and it sounded like the silicon end seals absorbed the shock.
4 - The lower gasket on the passenger side was misaligned a little (noticeable when looking at the right front coolant port). I was so nervous going through the steps that I didn't notice when I placed the gasket. I followed the Hayne's manual torque sequence. When I retorqued the lower again the next day, most of the bolts turned a little except for the one that helps hold the heater tube. Same behaviour after I torqued again after a couple of heat cycles. Below is a pick of the gaskets just before dropping the intake:
Anyway if there's anything that seams off with what I did above, please chime in with any words of wisdom. I don't want to repeat the same mistake(s) again! Thanks.
