i just installed my novi and everything went fine but when i started it the pressure is between 60-70 i have 30 injectors with a 6-1 fmu i havent hooked up the boost gauge to see wat the vacume is i tried adj. the regulator but it didnt move the timing is at about 8* anyone now wat would cause this i was told its either the fmu,regulator,vacume leak is there anything else it could be or how do i check the fmu,vacume ,regulator thanks i also have a bbk inline pump but i didnt put it in yet with a 255 intank pump that is in
I have my novi and 255 lph pump coming, the guys i ordered them from, said I would need an adjustable fpr because the pump will raise the fuel pressure 10 lbs. not sure what the problem could be with your setup?
has anybody taken apart the bottom half of a fmu i read the directions and it said not to take it apart if so it would have to be replaced but i alreadt took it apart to put the fittings on could this cause my high fp thanks
