as soon as i hit 90 and over the steering wheel has major vibration,under 90 its fine.could my front tires need rebalancing ?
i also notice that when i brake i also have vibration in the wheel.
I wouldnt over react that is prob all it is.
Go get you **** balanced and aligned.
Rotate your tires from front to back (given they are all the same size) and see if the vibration is no longer present at the wheel. Usually if a rear tire is out of balance you will feel some vibration in the seats. Also, since you feel the wheel vibrating as you are breaking, you might also have front rotors that are a bit warped. Good luck.
Dude check the air pressure in the tires first I think the norm is around 32-35psi depending on size and style. If you are expirencing a shudder in the wheel when you brake check the rotors and pads something is probably up with them. rotate and balence will help if it isn't a rotor problem.
