My emergency brake light keeps on coming on. I checked my fluid and it was low so I filled it up again. I then noticed that under the brake reserviour there was a liquid next to he engine. It is all over that part. I also scraped it with a long stick ad the paint came right off. Is that brake fluid? If it is then I know where the leak is. How much does a new brake reserviou cost>? Thanks
Yup, sounds like brake fluid (because it stripped the paint).
Check your cap to make sure it is on tight and not cracked.
Check the fitting on the M/C to make sure none have come loose.
Check the brake lines for cracks or other signs of stress, kinks, or other damage.
