1 - 8 of 8 Posts
Can't go wrong with TRW/Moog front end parts. Any local parts house should have them...about $35 each.
Steeda X2 balljoints work really well. Change the geometry if your car is lowered to help handling. I love mine.
I am replacing mine as well, but, since I will need an alignment anyway I am also going to replace the A-Arm bushings, the Tie-rod ends sway bar bushings and the bushings and rods on the end of the sway bar (not sure the name). I purchased the complete rebuild kit with all of this from PST for $189.
In addition, I am also going to replace the steering rack bushings with solid aluminum bushings from Maximum Motorsports ($40). Poly ones can also be had from PST for $10.
I don't want to have to tear it apart again and pay for another alignment in the near future.
SN95GT50
Yeha- I am doing all the bushings also. I bought a set of A-arms from the junkyard, and I am going to replace all bushings and and the balljoints, struts and springs while I am in there.
Whats the deal with the steering rack bushing? How hard is that to replace?
GG
MM Aluminum Bushings
Instructions for MM Aluminum bushings Steering rack bushing install directions The poly bushings from PST would be an easier install, but I want the solids.
I have a squeeking coming out of the front end and I have 91k on it. Someone said that the steering rach bushings can cause sqeeking, I doubt that in my case. Like I said before, while I have it apart I am doing everything.
SN95GT50
1 - 8 of 8 Posts
