do you really think a solid roller is worth that much more power? do you think the gains just came from how much bigger it was? i figured it would be worth some power, but it basically just crushed the hydro roller all over the curve.
another question for you N/A guys..... i see alot of you guys run cams that are 230+ in the intake and still have decent low end performance. i ran a 230-236 544-555 114 and it was a sled under 4k. swapped to a 274HR and picked up all over, even with less boost. is this because of haveing more cubes? mabie my 114 couldnt scavenge enough to make it torquey on the bottom?
thanks
thanks
