Question is I have this Comp Cam: Camshaft Lobe Separation 110°, Duration 242°/248° @ .050" lift (int./ex.), Lift .594/.618” (int./ex.). Only spin it to 5900rpm.
This is in a 460sb. It idles extremely rough. I can't lock the converter till 1800rpm or my Bronco is bucking as I'm going down the road.
I run a Moates Qtrhorse, EDIS and Decipha has it dialed in well. Idles great at 750rpm even with 6.3" of vacuum.
Would a cam designed specifically for EFI gain enough HP & torque to really notice? It's a radical arse cam, sounds great, ton of attention but I really want more power out of it if it's available and I would think that a 114 or LSA in that area would help the EFI get the signal it needs for idle. I
