I recently bought a set of used AFR 185s. How can I tell for sure if they have the upgraded valve springs? Are there measurements I can take? Do I need to remove the springs to do it? Thanks-Dan
I belive you can just look at the paint schemes on the springs and then measure the thickness of the spring and then call AFR or go to their website. This will allow you to determine what springs you have. I have the AFR 205's and went through the same hassles of determining what springs I had.
GOOD LUCK!
