If the compression test and leak down tests are within specs and you have no fluid contamination (oil/radiator) then does that mean your head gasket is good? My car is overheating w/AC on and radiator, thermostat, sensor, water pump are new and everything else has been tested and checked.
Wayne
Check to see if the fan goes into high speed when the ac is turned on !! Also theres a GP for a badd ass 2 core fluidyne radiator you might want to get living in new mexico !!
