Hey, I know there is 2 bolts that holdin smog pump. Reach them from underneath the car. How many connections and fittings are attached to the pump and where do they go to.
I'm not sure exactly how many connections there are, but just removove them all along with the rubber tube coming to it and thats all. Also, dont forget about the tube going into the h-pipe, you're gonna have to cut it off.....good luck
Can you still pass emissions with the smog removed?
hey why good luck
the h pipe tube is easy to take off, then one tube coming out of smog pump into canister and remove the canister thing i geuss, then the little tubes also
