Installing a Autometer speedo that is driven off of the pulses from the VSS on the transmission. Want to remove the speedo cable completely so is there a plug to put into the speedo cable connection point on the VSS sensor? Is the better solution to just install the VSS sensor off of a 94-95 mustang that does not use a mechanical speedo?
I need the VSS to get the electrical signal for the Autometer speedo. I just don't need the mechanical speedo cable anymore so I want to take it completely out and plug the end of the VSS where the cable used to go. Problem is I cannot find a plug for it and I read that the 94-95 VSS's were plugged from the factory being they did not use a mechanical speedo cable. So I am wanting to verify that the 94-95 VSS is in fact plugged.
