I've seen this on the SN-95+ cars and wonder what all you need to do in order to do it on a older model. I ditched the A/C and smog this year and like the look of the P/S up around where the A/C normally goes. My car has a 351 if that matters.
i believe you can get the bracket off of a non-a/c mustang, or just buy the fms a/c delete kit... either way it will move the p/s pump where the a/c used to be.... hope this helps some
~paul
Correct, the FMS A/C delete kit will move the P/S pump "up" to where the A/C compressor was.
When you get the FMS brackets, don't forget to get the ones for a 351W. The brackets for a 302 won't work. The bolt spacing is different on the brackets due to the increased deck height.
I have the relocation brackets on my 302. I like where the P/S pump is this way rather than using the March A/C delete kit. It really cleans up the front of the engine when you lose the A/C and smog pump and run a nice short belt around some shiny underdrives.
later,
Mike
Yes!
I didn't catch the "359" in the sig.
You will need the 351 brackets. I believe these are also available from FMS.
