Hello all.
Currently running a Holley Blue and the regulator that comes with it. Is it possible to hookup a return line to this regulator? If so which port on the regulator would it connect to and what size would the return line be? 3/8's?
I have the fuel pump mounted near the tank using a 3/8 line with a fuel filter before and after the pump. The regulator is mounted on the passenger side strut tower and of course a line going into a 600cfm holley carb. All this in an 85GT. Off one of the ports i am running an autometer fuel pressure gauge.
Thank you in advance! Sorry about all the questions.
X.
The Holley Blue doest require a return line. The reg you have has two outlet ports and you 'could' rerun one back to tank but I dont see the need for it??
Thank you for the reply. Sure saves a lot of work for me anyway. I did not know it didn't require a return line. heh :)
How does it deal with excess pressure though? I figure it would build up at idle putting strain on the fuel pump and reducing its life expectancy.
Regards.
X.
