I am having trouble with my car and I want to do a cylinder balance test. What does this test do and how is it performed? What will I need?
do I just need one of those "beep" code readers? how do I get the cylinder balance test started?
Basically the cylinder balance test turns off injectors one at a time and then the EEC checks the rpm drop. After all the cylinders have cycled through it checks all of the rpm levels and if one cylinder or more make no significant decrease in rpm then it flashes the cylinder number on the code reader to which cylinder it thinks should be checked.
To start the test you have to go WOT after the cylinder ID test flashes on your code scanner. I'm not sure this test works for all years but it did for mine
Bill
Re: cylinder balance test
wot is only for '86. other years you just tap the throttle.
