If I pull off my timing chain,etc.. so I can see my cam, will it say E303 on the end or is it on the other end?
Supposedly my car came with a E-Cam, but im tending not to believe it do to other things on my car.
They're not all marked. Easier than pulling the front cover - set up a dial indicator on the number 1 rockers/pushrods, and put a degree wheel on it. Measure the peak lift and duration. The E has .311" lobe lift, 220 duration at .050" lift; 282 duration at .006" lift. If your measurements match those, you've got an E.
Discussion Starter · #5 ·
OK, thanks for info
Argh there not all marked?
Discussion Starter · #7 ·
Argh oh well looks like i gotta pull it out or do as Michael Suggests thx for info.
