I just ordered the SPEC Stage I clutch kit for my 97GT but now i was wondering what i can do to adjust the clutch pedal, its a bit too high up and I will like to lower to the floor a bit, what parts do i need and where can i get them from?
PM Blown46Cobra for info on his clutch pedal height adjuster. However, it requires an aftermarket quadrant. I vote for the UPR pieces, but stay with the stock cable.
Here you go... Works like a charm....
http://www.flash.net/~ivc1/cobra/pedaladj.html
You will need a Firewall adjuster and an aftermarket Quadrant in order to make this work....
I recommend the UPR.. It's first quality and a little cheaper than the Steeda kit...
Good Luck..
Tom in Indy
