I were running on less than 8 cylinders. I did new plugs yesterday and my engine seems to rattle/shudder/vibrate a little more now when I shut it off as it comes to a hault. Any idea what would cause this?
check to make sure a coil hasn't come loose, not real familiar with coil on plug but make sure everything is plugged in.
phil
It should be pretty obvious, however I had a defective plug wire and only had a problem under moderately hard acceleration.
