In an effort to prevent my 351W from burning rod bearings I installed shims under the spring in the oil pump. Now, when the engine is warm it idles on 80psi. When you rev it up to about 2000rpm its on 100psi. Any higher than 2000rpm it pegs the needle all the way back to zero!
Is this too much? I'm not worried about it busting the oil filter because I have one with a thicker shell. I have no leaks either. I have a bronze distributor gear and the stock 3/8 oil pump drive. Am I in any danger of breaking the oil pump drive? How long do you think the gear might last?
