Stupid Haynes manual just says fill it until it is full basically. I don't want to buy more than I need and don't want to have to run to the store and buy more while filling it.
Please, someone tell me how much fluid the rearend will take and also how much the tranny will take? I'm not draining the converter, just basically doing a filter change.
AOD???? You should only need 4-5qts to replace fluid if doing a filter change.
Diff takes about 2.5 qts plus limited slip additive. The diff is full when the fluid flows out the fill hole.
hope this helps
hope this helps
Yeah, AOD. Forgot to mention that. :eek:
Yeah, that is what I was looking for. The Haynes manual said what you said about the rear diff (fill it up to the hole, but I wanted to know about how much to buy.
Anyway, thanks a bunch.
do you just want to put in 1 bottle of friction modifier to the diff?
thanks,
adam
