I have a 2031 cam and i need new pushrods. Does anyone know how much it cost to buy them from crane cams. or anywhere else.
Summit Racing:
It's either:
CRN-36623-16 $80
or
CRN-36625-16 $129
I am not sure what the difference is, but I am sure it will end up being the more expensive set. :) They both look like they are the 6.375 which are .117 longer than stock.
I was just looking into this myself.
Hope this helps,
Don
that is wierd. i have herd that 6.310 is the correct lenght.
6.300 is a tad short
and
6.350 need to be shimmed
That is just the size Crane has. I have read that people use them, but you would have to shim, probably. You really need to measure your setup to be sure of what you need.
I didn't know that you could get 6.310s off the shelf from someone else. After replying to you, I saw the other thread you posted on. Lots of good info there. Go by what they tell you, as I have only researched and have not done the install yet.
Make sure you let us know what worked for you!!
