That Rear Wheel hp.I’ve often wondered if that’s on an engine dyno or rwhp.
The parts on it are fine for now so I haven't done anything to the rear suspension yet, too many other things to worry about first.Really surprised to see you don't have your own suspension listed as installed in the rear of that car. Are you really not using your relocated uppers?
Those weight jackers must work really well. Im only making 560 and I couldnt imagine using anything other than the Baseline setup. That one upgrade completely changed my car from a traction perspective.The parts on it are fine for now so I haven't done anything to the rear suspension yet, too many other things to worry about first.
ks
I use the baseline street outlaw kit because it gives the most adjustability. My car is lowered so any time i got on it, the tires would just spin and the rear would squat. Now it stays flat and the nose comes up. My guess is at 700+ you would need the regular outlaw kit that doesn't use any poly bushings. Baselinesuspensions.com is where you can read about their system and order.Please go on! I need traction help.
I purchased some rear lower control arm relocation brackets to increase my antisquat but I haven’t installed them yet. I’ll read up on this. As it is now, 3rd will never hold without traction control and 4th is a coin flip.I use the baseline street outlaw kit because it gives the most adjustability. My car is lowered so any time i got on it, the tires would just spin and the rear would squat. Now it stays flat and the nose comes up. My guess is at 700+ you would need the regular outlaw kit that doesn't use any poly bushings. Baselinesuspensions.com is where you can read about their system and order.
I also have different lower brackets but i don't think they made much of a difference other than being able to set the ride height where i want it. My lower arms are essentially parallel with the ground and my uppers are set to do it gives me like 10% anti-squat. It makes a world of difference. As i said before it's the single best suspension upgrade I've done to my car.I purchased some rear lower control arm relocation brackets to increase my antisquat but I haven’t installed them yet. I’ll read up on this. As it is now, 3rd will never hold without traction control and 4th is a coin flip.
QUOTE]As it is now, 3rd will never hold without traction control and 4th is a coin flip.
Nice problem to have 😍
Just out of curiosity, what size tires are you running?I purchased some rear lower control arm relocation brackets to increase my antisquat but I haven’t installed them yet. I’ll read up on this. As it is now, 3rd will never hold without traction control and 4th is a coin flip.
275/40ZR17 on 17X9 original 95 Cobra R’sJust out of curiosity, what size tires are you running?
