I am in the process of getting a cam for my 93 GT with a powerdyne. The supporting equipment is in my sig so could you please comment on these cam numbers, how do you think it will work out.
Thanks a ton,
Eric
with 1.6 rockers
.544 lift on int. and exh.
294 degrees at valve or [email protected] int.
302 degrees at valve or [email protected] exh.
112+4 lobe seperation, I guess that is 116, dont know yet. They said it will have two degrees advance.
Any comments please. Thanks again.
with that much duration the car might be alittle week down low, should sound good and come on hard, I also would wory some about idle problems
Thanks for the reply. I told them that I needed a cam that would idle and make vaccum for my brakes. He told me on the phone that this cam would do that. I will be calling back today and either giving them the go or no go on making it. He said that the cam should make boost lower but is only good to 6000. Which since my car is a street car that is fine for me.
Thanks,
Eric
