Well basically what it says:lol: How do you set your TPS? Do you need a voltmeter and what is a good setting to have it at if you have a E-cam with a very lopey and low idle. I am having problems trying to get my car to idle properly and I have tried messing with the timing. What would the best timing be for this cam. Thanks for the help.
Ivan
Super Moderator
A search would be greeaaat, m'kay?
Get your self a digital ohm meter...with the key on engine off put the + lead on the green wire going to the sensor and ground to the throttle body. With the two phillips screws loose on the sensor itself twist it to get your setting. Ask 5 people what you should set it at and you will get 5 different answers most likely. I run mine at or around .96, seems to run best in that range. Some people say run it at .999...so try different settings between .940 and .999 to see what is best for your ride.
